Updated Mods List and Project Schedule
mikelv
566
12
Jun 17, 2006
Columbus, Georgia
I have decided to post up a progress chart and mods list to see where I stand and what I can do to make myself a nasty little street car. I’m looking to strip some more weight off the car, but as of right now she is 2940lbs with me in it. 2750lbs empty. I still have a few things to remove to hopfully get it under 2700lbs empty. From there I will go to some Fiber Glass and gut more than I can think of. Goal weight of this 2G while still remaining streetable is 2200lbs empty. Not sure if I can but we’ll see. Maybe a smaller fuel cell, lights, panels, parts, glass, dash, side exit ect…but I still would like it to be streetable. Here’s the latest list:
Engine/Cooling:
1991 2.3L 6 Bolt Stroker (Bored .20)
Eagle 4340 4G64 100mm Crankshaft
Wiseco Pistons (8.8:1)
Eagle H-Beam Connecting Rods
ARP Main Studs
ARP Connecting Rod Bolts
All Mitsubishi Bearings
Entire rotating assembly balanced
DKS Stage 2 Camshafts (272/272’s)
Crower Springs & Retainers
Fidanza Adjustable Cam Gears
3G Lifters
SI Competition Valves (STD Size)
Ported and Polished
Metal Head Gasket
ARP Head Studs
Fluidyne radiator
Spal 12” Cooling Fans
1G Water Pipe Insulated
PCV Check Valve and Catch Can
Injen Overflow Tank
Flexi’Cool SS Upper Radiator Hose
Turbo/Intake/Exhaust
Forced Performance 3065 Turbo
FP Race Manifold and Dump Tube
FP V-band O2 Housing
Tail 44mm External Wastegate (v-Band)
RRE Custom 3” Exhaust (one section)
All Exhaust Wraps and Turbo Insulator
FP 4” Intake and K&N 4” Air Filter
GM 3” MAF
Slowboy Racing 2G FMIC Kit
Turbo XS Type H CBV
60mm TB (extrude and honed)
1G Intake Manifold (extrude and honed)
NX Express Intercooler Spray Kit
Fuel:
1G Fuel Rail
FIC 1050cc Injectors
Aeromotive AFPR
8AN SS Braided Fuel Feed Line (Tank to Rail)
Walboro 255lph Fuel Pump (10 gauge hard wired)
Fuel Lab Fuel Filter
Electronics/ Electrical and Engine Management:
DSMLink V2 ECMTuning
Apex Dual Turbo Timer
MAF-T Translator
AEM Wideband O2 52mm A/F Ratio Gauge
Autometer 60 psi 52mm boost gauge
Autometer Phantom Electronic 52mm Oil Pressure Gauge (SS line wired for sending unit)
Apex Peak/Hold EGT 52mm Gauge
EFI 30psi 52mm Vacuum/Boost Gauge
Autometer 52mm Water Temperature Gauge
Jegs Battery Relocation Kit (2 gauge wired)
Stinger 1 Farad Power Capacitor
Stinger 24K Gold Power and Ground Distribution Blocks (Front & Rear)
Magnicore 8.5mm Wires and NGK BPR9ES Spark Plugs
1G Coil Pack
1G CAS
Drivetrain/Brakes/Suspension
John Shepherd Stage III Transmission
Double syncroed 1-2 & 3-4
4 spider Differential
FCU Removed
SS Shifter Bushing Kit
B&M Short Throw Shifter
DSS Stage II Drive Axles (600hp rated, all Four)
Tokico Illumina 5 Way Adjustable Gas Shocks
RSR Springs Kit
Ingalls Adjustable Camber Kit
Stillen Front and Rear Strut Stabilizer Tower Bars
Wilwood 4 Piston Caliper Front 2 Piston Rear, Brake Kit
12.9 Inch Power Slot Front Rotors
11.5 Inch Power Slot Rear Rotors
SS Braided Brake Lines
Michelin Pilot SX 225/40ZR18 Tires
SSR Wheels (17lbs each)
Body/Chassis/MISC:
Stillen Front Bumper Cover
VIS Side Skirts
VIS OEM style CF Hood
A/C Removed
C/C Removed
Rear Wiper Arm and Washer Bottle Components Removed
Radio Removed
M3 CF Side Mirrors
Custom Center Taillight
Aerospeed CF Rear Spoiler
New Installs and Products yet to be:
DSS Drive Shaft Install
Hallman Pro MBC
NX Express Intercool Spray Kit Install
Fuse Box Relocation Project (Harness Reconditioning)
Clutch Situation: Twin Disc vs Current ACT setup
Current: ACT 2600 with 6 Puck Race Disc
Current: ACT Flywheel
Gauge Wiring and Power Distribution Block Assemblies
2G SS Braided Clutch Line
Restrictor Removal from Slave Cylinder
ABS Removal Project and SS Brake Lines Install
Power Antenna Removal
Low-rise 95 rear spoiler Install
OEM Front Bumper Install
17” Eagle Racing Wheels (G-Force Drag Radials)
New CF Hood Install
ARP Flywheel Bolts
ARP Crank Bolt
ECU Harness Reconditioning and Elimination (thanks for the blog turbosax)
Future Projects and Plans:
Shep Built Transfer Case
Shep Built Rear End
Driveaxle Upgrades (Stage 6 rear)
CF Hatch and Glass removal
CF Door and Glass Removal
Rear and Front Sub Frame Bushing Install
Prothane Suspension Bushing Kit Install
Coilover Suspension Upgrade
Side Exit Fabrication
Roll Cage Install
Parachute Install
Engine Management Upgrade
Current Weight of the car: 2850lbs empty, and that’s about it. Can’t think of much more off the top of my head, but I’ll get it right! If you guys have any input or thoughts on some of this feel free to post up. I love a good technical discussion.
I will be posting daily with updates and technical instruction as to where and how I am doing things. If you guys know a easier way, better way or just plain something I’m missing, I would most appreciative of your advice. Thanks guys for reading!
Mike
