unplugged injector cause no power at boost?
magik95
401
Feb 24, 2008
aurora, Colorado
Ok well I developed a problem all of the sudden while on a drive that appears to be a big ass boost leak.
So I do a boost leak test all the way around and found little leaks in the biss and in the j pipe.
I fix the biss leak by replacing the oring, and by putting new shaft deals in my n/t tb. No good still the same problem which is at boost the car has no get it and go, runs way rich.
The car runs fine up untill the turbo starts spooling.
I checked all couplers and pipes, bov, etc. I know the turbo is good I just rebuilt the thing about two or three weeks ago.
So just as of right now I was checking every thing and came across the number four injector's plug was not connected all the way just kind sitting on the top of the injector. Its late as hell and dont want to pull it out of the garage. So my question is to anyone is Could this be my problem?
same problem 97 talon nt-t
Same problem?
You found an injector unplugged an wondered if this may be a problem, and now it's too late to drive your car?
Drive it and see... WTF It's still (barely) light outside even here on the east coast.
