Unknown vaccum line...where's it go?
Methodryder
Apr 1, 2005
Minneapolis, Minnesota
I'm finishing up the install of this turbo and i bumped into this problem...(2nd gen t28 install) There is a vaccum line that runs from the boost accuator/sylenoid and the turbo housing that t's to a junction that runs to a line that has broken off from an unknown location...can anyone tell me where this is routed to? Thanks
If you have a boost controller don't worry about it, if its a BCS setup then there should be one hose going RIGHT underneath the intake, and another hose should connect to the wastegate.
If you can't figure it out, connect the compressor nipple directly to the actuator and remove the t. This way you can safely run at stock actuator level, around 10-12 psi, until you get a mbc.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
