under hood busings center metal sleeve
lachy21
Feb 23, 2006
Atlanta, Georgia
Hey guys, I recently bought the brass bushing for the shifter cables (under the hood). I was able to remove the rubber stock ones from the top one easily, but the bottom one was tough. I managed to get it off only to realize that the center metal sleeve was still attached to the rod. Does anyone know how to remove it? I tried pulling it with pliers and tapping it and nothing. Please help.
Try a drop of lube, tapping some more, and twisting it off with pliers. If it is still a no-go, just cut it off.
Although I haven't had your exact problem, I have had bushings stick like that. I generally try to heat them up with a propane torch. The different rates of expansion for the metals generally makes it easy to slip it off. If that doesn't work, like locke said, cut that sucker off.
Thanks alot guys, I'll try to torch it out when I get home from work.
Thanks alot Steve, I'll try that when I get home from work.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
