Unable to put back steering column
Prolab
Jun 11, 2009
Brampton,
So i pulled out pedal assembly to be welded but to my frustration, i took the steering column out of the way so ive got a lot more space to work on.
Well, now that pedal assembly is in, im having a tough time re-installing the steering column back into the lobro joint.
Now, the first time i did it, i thought it was all the way in. So i started putting the screw in and tightening the crimp. Well, it wasnt even on and i believe i just end up making the crimp even smaller.
Ive tried greasing both the shaft and the lobro end joint but everytime i tried putting it back on, i can feel the grooves match and as soon as i pushed the column forward, the joint wont go in straight.
Is there a trick to this? Do i need to expand that lobro joint so it accepts the steering column shaft?
I've tried searching but i only came up with for a 2g. And it didnt even come with instructions.
if you have already put the bolts in it and tightened, and it wasnt attached yet then the bolts probably squeezed it, try to open it back up in small doses.
