two questions
1gengsxz3
129
Jan 25, 2007
Novato, California
First what is the diameter on a stock 2g throttle body elbow? two i bought a mbc that has a set stock psi of 11 and then i can set my high psi to what i want i want your guys opinions on what i should do for my car right now it's running 7psi and it has stock everything except catback exhaust and cold air intake pipe and fmic it has 140xxx on the engine and i really dont want to explode. should i just wait to put the mbc on till i get my new engine in a couple of months?
The stock 2g TB elbow is 2 1\8".....My opinion on your boost situation. It sounds like you have done what needs to be done to safely run a 14psi(on a 1g,AKA my car) so i would suspect you would be able to run the 'stock' 11psi no prob, even in driving hard conditions. With you getting the new engine in a couple months aswell, it makes a bit less of a concern on the engine, I dont think 11psi will hurt it at all! :) :thumb: my .02
