two questions
eclipse-gst339 said:
how many psi of oil pressure supposed to have at start up? how do you check trouble codes
Oil pressure is high on start-up, I think mine is around 80+ pounds.
Trouble codes can be checked with either a logger/computer if you have an OBD II adaptor, otherwise you can borrow one from Autozone and they will check them for you.
it's a 95...OBD I
  • Wanted 6 bolt NT water pipe
    • chrisman287
