pgt1996
- 0
- Sep 2, 2003
Columbia,
Missouri
To all,
I am reading up about changing the timing belt on my 6-bolt motor and had a question concerning the crankshaft moving while trying to loosen the cranshaft pulley bolt. I imagine the crankshaft is going to move (from past experience on changing timing belts on non-interference motors) when I either bump the starter to loosen this bolt, or use a strap wrench to loosen this bolt, but the timing belt change procedure on the vfaq site warns against the crankshaft moving with the timing belt off. (http://www.vfaq.com/mods/timingbelt-1G.html) If all of the valves are closed at this point in time, and the timing belt off, what would be the problem with turning the crankshaft clockwise, or even counterclockwise to re-align my timing mark? Any help would be greatly appreciated. Thank you,
-Tim
-Tim
