Moonlight GSX
- 686
- 154
- Nov 16, 2010
Hagerman,
Idaho
Of all the turn signal threads I have read none of them have cleared up what exactly I'm looking for, and what I'm looking for is this:
Before I swapped my interior wiring harness, located under the dash, I had a signaling problem similar to that of everyone else. When I swapped it out with one that was fully functional the problem still remained and did the exact same thing minus the "draining" of the back lighting on the gauge cluster (still does it a bit). I then proceeded to have two mobile mechanics, who knew nothing about wiring what so ever, look at it and thought maybe it was the switch (which was already changed out). Now, after they had "figured" the situation out, the turn signals are on the other side. I suspect that possibly there is a ground bad somewhere but where? I've checked everything, to include all grounds in the rear and inside the car. I've also gone to the extent of changing out all light bulbs, minus the head lights as I've recently replaced them, and I still haven't gotten them to work properly... any takes?
