2G Turn signal NEVER works!
So I grounded pin 8 9 and 3 . no change????
Pic shows me putting ground wire on pin 8.
OK so it did work. Both left and right signals yay! But then I pulled off the ground cable, and now it works fine with out the ground. WTF is that about? And just like that!
No it stopped working again. OK, so I'm noticing that now when I press my e Flasher's, it week hesitate and not blink unless I press on and off real fast. Then not only will the e Flasher's work but my turn signals also work. But for how long idk??
yeah seems like it, do you know were the actual original ground is for the turn signals?
like i said i figured out how to more or less make this work, i have to get crazy:beatentodeath: with the e-lights and turn signal switch at the same time and it seems to force it to work.
wish i could of actually resolved this.:cry:
Manual shows that ground is under drivers seat (and carpet) on top of cross member.
If fixing doesn't work, at least try permanently wiring that pin 8 to ground (chassis). Splice into it so where rest of wire goes will also be grounded.
