Resolved 2G Turn signal issues
jesse12345
1,255
1,101
Jul 30, 2014
Minnesota
I'm having a weird problem with my drivers rear turn signal not working. I had my flashers on to test for power in the back and sure enough I have no power. It's also blinking fast which makes sense. Is it a relay behind the radio that causes this or is it an actual module? My passenger side works perfect and all brake lights work its just the drivers rear signal. I've found similar issues but none of them had exactly what I'm experiencing.
Solution
Well I figured it out It was the ground wire that grounds to the bulb housing. I don't know how I missed that but it all works normal again.
Well I swapped the flasher module with my other car and it works but now both sides just flash fast. Am I missing something? If I don't have the little bulbs on the sides of the bumper hooked up would that cause this? Someone snipped those right off.
On an analog system that these cars use, if there is not enough resistance, the bulbs will flash faster. The side marker lights add to your resistance so they will help.
You can’t just substitute led bulbs or else their lack of resistance will result in fast flashing.
Turn signals work in reverse: the power to the bulbs is constant and the flashing is controlled on the grounding side.
Alright I'm back with the same issue except now both sides blink fast. I changed all the bulbs with new ones and both sides flash fast. I looked at all the bulbs and they all work so I'm kind of at a loss now. I replaced the module with a know good working one so I don't know what to check next.
