Turbo Wing Wrapped In Carbon!
LOL:laugh:, cmon guys just give me some info without busting my carbon balls.;)
LOL!!
You would have to find a body shop that can get sheets of carbon or you can order the sheets and try and do it your self.
not sure what you mean by that but they just sell like sheets of the stuff. you can overlay it on anything you want I suppose
Well how would get it to adhere is what I mean? Does anyone having any information on this?
they have some self adhesive ones or you just use some sort of glue I am assuming. I am sur eit isn't as hard as it seems
Ok I am gonoing to look into this. BTW L2RTSiAWD, the conversion looks awesome so far...:thumb:
yeah its not bad price for the sheets either, you can really do alot with them. not sure how it would work on a spoiler but that would look really cool
Originally posted by EclipseGST-95
id say dont waste your money in looks for the car n get started on that 700 hp u were talking about:thumb:
Oh don't worry, it's already being built.
Originally posted by kevingst
AGH!! L2RTSiAWD...what happened to your cf hood?
HAHA!!!!!
Ya it's gone, I was bringing the body back to stock and ran into a money issue so now I'm stuck like this for while:
Say these mods:
Modified Stroker block (6 bolt crank platform)
Fully Cryoed block, crank, rods, and pistons
GReddy big front mount
GReddy Plumbing
GRedyy Type S
990cc's
Weldon racing pumps
AEM EMS
Custom Wiseco Pistons (8.5:1 ratio/.020 overbore)
Eagle Rods
ARP main studs
All new freeze plugs
Balance shafts removed
Butcher crank
New oil pump front cover
New oil drive gears
Line hone, torque plate boring, decking, and plateau honing of block
Assembly of shortblock
Balancing and blueprinting of rotating assembly
File fit rings
All new bearings
1G reconned oil pan
Cryoed Level 3.5 head (1mm oversized valves)
New “big hole” lifters
Head “wings”
Crower spring kit (titanium retainers/springs)
HKS 264/272 Cams
New cam seals
Cometic head gasket
Fidanza adjustable cam gears
1G Coil Pack
Powercoated rocker cover (your color of choice)
1G T-Stat Housing and outlet
’90 CAS
1G Water Pipe (refurbbed)
Lower Radiator Hose
Magnecore Wires (1G)
1G Water Pump
New Timing Belt Cover
Timing Belt Undercovers
Magnus Sheet Metal Intake
Fidanza Aluminum Flywheel (6 bolt AWD)
Stainless steel rocker cover and oil pan bolts
1G timing belt kit
Modded motor mount (timing belt side)
...all of this on a 6bolt in a 2G GSX.
this is without my nitrous and a few other things.
NEW! Our new Carbon Fiber Sheets are available in several thicknesses and sheet sizes. The 0.2mm comes single side finished and with optional adhesive backing. All others are double side finished. Currently we're offering all of our carbon fiber in the latest 2x2 twill pattern which creates a subtle horizontal striped pattern.
http://www.hayameperformance.com/carbonfiber.htm
So wait I can cut it out, stick it to shit and then just clear it??? That's awesome!!!
give me 20 bucks and a black and grey sharpie and ill draw ont hat bi*** and make it look CF for you!!!!!!
:D :thumb: :cool:
