99GSX Swede
- 57
- 0
- Aug 29, 2004
Hillsboro,
Oregon
Not sure if anyone has experienced this. I was not able to find any threads on it from my searches.
I have been trying the two different ways of hooking up a MBC as discussed on multiple threads. I had always ran my MBC with its vacuum source from the intake manifold and thought that I would give the compressor housing a try, to see if it made any difference on boost spike or spool up.
After hooking up the MBC to the nipple on the compressor housing, I noticed a slower spooling turbo. No improvement with boost spikes but I did get what at first felt almost like fuel cut. I though this was strange since my boost level was the same as it was when I got my source from the intake manifold. I lowered it by approx 1 psi and tried a 2nd gear pull. Within 2-3 seconds I hit what almost felt like fuelcut and this time my service engine light stayed on (boost was at 17psi). I checked the error with my logger and it showed as a Turbo Wastegate open error. WTF
Has anyone experienced this? Why would the wastgate blow open when hooked up to the compressor and not the intake manifold?
The MBC I am using is a Joe P. Before that I had a Turbo XS but I switched to try to reduce boost spike as well as that annoying bleed of hissing under the hood.
I have now switched back to the intake manifold and everything works great and I was able to turn my boost back up to 19 psi all the way to redline.
