Service Engine Soon light.
750_sport
70
Feb 17, 2005
Sacramento, California
Is this a check engine light? is there a way to reset it?
Mine turned on today. I got the car about 30 min before hand. After lay on the throttle in second gear it came on.
I need to go pick up a obdII scanner tomorow.
They're the same thing.. disconnect the battery and let it sit for a while, this will reset the ECU. If there's still a problem, you'll probably throw the same code again.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
