2G turbo upgrade help from my stock t25
boosted 96 eclipse
104
Aug 4, 2012
Cheyenne, Wyoming
I was wanting to upgrade my t25 turbo but i have no idea where to go to get a bigger turbo i want to produce about 400hp from my stock engine is that possible? Should i go with a t28 or a 16g turbo evo III? I would like to change my injectors to 550cc with a walbro 255fp and an aftermarket fuel rail and regulator. But i have no idea what the best sites are to get parts for my 96' gst
So much BS and not enough solid posts.
Start reading here> Tech Guide - DSMtuners
A DIRECT bolt on is the fp big t28. For a t25 almost anything is an upgrade and goes something like this>.. 13g,14b,small 16g,big 16g,big t28,evo 3,evo x comp wheel,18g,20g in tdo5 or tdo6,billet comp wheel, and then the 68hta.
I'm sure I'm forgetting a few but thats the basic idea. BTW Gofer on the 68hta is a freak of nature:)thumb: Corey)..
Yes the t25 is a joke
quote from a book i have
" at a 2:1 pressure ratio t25 = 330 CFM, 13g = 360 CFM, T28 = 400CFM, 14b = 430CFM, Small16g = 505CFM, Evo3 16g = 550CFM, 18g = 590CFM, 20g = 650CFM"
Atleast you realized it. :thumb: But as you can see were not gonna spoon feed you when there is millions of threads like this and even several upgrade paths and even guides on installing certain things in these said paths.
I have set my stage 1 goals than after my stage 1 goals i will work up a list for stage 2 goals. I will just keep going at it in stages until i get the car how i want. I have learned not to be stubborn and that these cars have a lot to them to get more ponies other than just slapping in a bigger turbo. Thanks again guys!!
