turbo trans compatibility
steelzeus
Feb 10, 2008
statesville, North Carolina
Hey guys are there any of our trannies in any other cars that will fit a 91 laser fwd turbo. From what i have read the 95-99 ones will if i swap over the cv shafts too, due to the larger size. but are there any other mits. that use the same turbo tranny? I'm doing a at to man swap and am having trouble locating a turbo trans.
all turbo fwd's have the same trans, eclipse, talon laser all have the same trans from 90-94 i believe, as far as a 2g trans might be a fun install considering there mounted in the car totally differant
the cable brackets on the 90 are a bit different, you can put a 2g trans into a 1g (not the other way though) and you can use an AWD if you want a little lower first gear (must use a VCE) take your pick.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
