Turbo Timer not functioning properly...
SuperSleeper
204
Jan 27, 2004
Farmington, Minnesota
So I just installed an HKS type 0 turbo timer into my 89 minivan. Red wire went to battery, black to ground, blue to accessory (tapped into stereo harness), and green to the main ignition (self-splice connected into ignition harness)
I believe everything is hooked up correctly, but when I turn the key off it shuts off. Do I need to have the e-brake or RPM sensor wires hooked up in order to make this thing work? Please help--thanks.
Dane
Try the (M) button in the upper left corner. After you start the van push the button until the display shows the amount of time you want to count down, I think it's 30sec, 1min, 3min and then leave it there. Shut off the van with the display showing your count-down time and it should work. Good Luck.
BTW-If that doesn't work, give us the info on your van...make, model, etc... and maybe we can get a vehicle specific diagram.
I had this same turbo timer on my Laser, so I know the basic functions of it. But that had a harness... :/ It was set at 30seconds when I turned the vehicle off.
The vehicle is a 1989 2.5 Liter Turbo Plymouth Voyager. Thank you!
Dane
Is it simply a ground signal? Because the van is an automatic--I don't want to hook it up to the parking brake.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
