turbo timer installation, please help.
Denji
Supporting Member
1,123
18
May 4, 2004
Calabash, North Carolina
Hey guys, i tried search, i didnt really come up with anything i found very helpful. I have a GReddy turbo timer i received from a friend for christmas, and all the instructions are in japanese. I think it came with a wiring harness for my car but im not even sure if its the right harness, nor do i know where to plug it in at or anything. Someone please help me out with any information. Installation procedure would be nice...possibly if someone could tell me what the eclipse harness looks like. I can take pictures if need be, just post something up for me! thanks - Brandon
I searched Greddy turbo timer becuase i have a Greddy turbo timer. I have no idea if there is a difference. My friend HKS monitors more stuff than mine does (i.e. 1/4 mile times, rpms, etc) so perhaps the install is different.
I got one for chirstmas as well with the harness(greddy) Its really easy... but i didnt hook it up to the ecu speed wire... I just use it manually and set it for a certain time. Just unbolt the lower steering wheel cover and the lower dash peice. And there is a big blue plug that comes out of the key ignition. Just plug the harness in there and your good to go.. Route the black wire on to a ground and thats really all.. The turbo timer will now work if you wanted to leave it like that. If not take off the dash piece to your right of your leg( very easy one bolt and a push pin) The route it to the e brake and pull out the cup holder and ashtray by just pulling out. The splice it in to the only wire coming from the e-brake. And your done... Now if you want you could hook it up to the ecu speed sensor wire but i didnt do that.
wondering where the speed senor is so i can splice the purple wire into there...pics would be awesome :thumb:
    • dsmmario
    • Detail
    • dsmmario
