Greddy Turbo timer installation
civickiller
119
Nov 6, 2004
Salem, Oregon
I am having tough time finding an ignition harness under the dash. Is it above ecceleration pedal or clutch pedal? I got harness for installation but cant find the ignition harness so i can put a "Y" spliter . i got 2g talon tsi. Please post some pics for installation.
Thanks :talon:
i have an eclipse but it should be the same.
take off the panel right under the steering wheel, then follow where you put your key in the ignition straight to the other side, that should be the plug you looking for.
Did you take the steering column cover off? If not, do that and you will see a plug on the bottomof the column. I think mine was blue or white. You can't miss it...
look at your steering column, now rotate your head to look underneath the column. youll see 3 screws take them out and the two halves should break apart revealing the ignition cylinder. around that area youll see the connector you need( just look for the male version of the harness), disconnect the battery negative post, then unplug the connector. plug in the connector and bam your pretty much done. From there youll need to hook up the timers security devices(my hks had parking break and speed), I have a hks so I cant help you there. good luck
    • dsmmario
    • Detail
    • dsmmario
