turbo stops making boost at 10psi!!
tt281gt
129
Nov 30, 2003
Downey, California
Was wondering if anyone could help me in figuring out why my turbo only makes 10 psi. I have NO exahust leaks. I even disconnected the vacum/manifold pressure line from the actuator and the max the turbo makes is 10 psi.
Is it a bad actuator? spring is 10psi.
oldman said:
Did you just install a mbc? It's possible you hooked it up wrong.
yup its a mbc. I double checked it, but ill triple check now. Im pretty sure its on right though. :thumbdown
From looking at your profile, where's your old mbc? try putting that one back and see what happens.
thanks for your help guys. We must all do one thing when we encounter problems on these cars, CHECK FOR BOOST LEAKS!! :p I know I know thats what were always told to do but I didn't and when I did I fixed my problem. I am not boosting 14psi ;) :D
