turbo seals
cyrez187
359
Dec 12, 2003
kelowna,
alright guys i have the t3t4 turbonetics turbo and im having a bit of oil in my intake and intercooler piping, now really good chance comin from the turbo. i was woundering if it is hard to take apart and replace the seals and if so is it worth it? thanks
Are you sure that's where it's coming from? You should probably figure that out first. How old is the turbo?
im positive its comin from that, i remember when i first started the car the oil drain line was too small so it was forced back and it was smoking like crazy so im assuming i blew the seals then. like its not really bad just a bit of oil in the pipes. is it hard to rip apart and replace those seals?
No. Once you take apart the compressor side of your turbine I'd STRONGLY recommend professional assembly. There is a very fine line of doing things wrong and right with a part like a turbo. They need to be balanced and done properly.
I didn't see this mentioned in Corbin's article. If the compressor nut has been ground down, mark it in relation to the shaft as well. If it was balanced by a shop in the past, they probably ground some of that nut away.
