Turbo oil/coolant line problem
Andrew Dahms
93
Aug 28, 2005
Terrace,
I have just upgraded my stock turbo from my 1991 Talon TSi automatic. The new evo3 16g turbo requires larger banjo ends on the three oil/coolant lines. Where can I get the bigger banjo ends and banjo bolts? Or is there another solution? Thanks for any help.
You're sure all of these will fit my 1g AT engine and an evo3 16g turbo? I ask because the water line kit on SBR is oem.
It is oem for a 14b car(manual tranny car) which shares the same size lines as the 16g. The tdo4 cartrige of the 13g uses smaller banjo bolts than the tdo5 of the 14b and 16g.
  • Wanted 6 bolt NT water pipe
    • chrisman287
