turbo noise when cold
motox-010
386
Sep 9, 2007
Spearfish, South Dakota
Whenever my car is cold, the first couple of times the turbo spools, it makes a weird sounding noise. You can hear it sucking in air, but it also makes another noise. I don't even know how to desribe it. It changes speed and pitch as the RPMs go up and it spools faster.
I guess the only way I can kinda describe it, is almost a whirring sound. Its not metal on metal sound.
Yeah, mine makes the same noise... its also very close to dieing though LOL. It smokes about 1/4 of the time you hit boost and has loads of shaft play.
Hmm, not sure what to tell you then. Like I said, mine makes that exact noise. Its sort of a high pitched whirring exactly like you described. I always just assumed that it was because it was just about dead.
Did you check the IN and OUT shaft play as well as the UP/DOWN shaft play?
Sure sounds like a bad turbo.
Check all of your accesory belts for slippage/glazing/rubbing
Check the harmonic dampener (crank pulley) Sometimes it will separate and start rubbing into the lower timing belt cover.
Water pump could be squeeling?
Bad alternator bearings?
A/C clutch bearings worn?
Anything that spins I would check....but the way you describe it sounds like a shot turbo.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
