turbo manifolds
erald01
661
Jul 6, 2007
canton, Michigan
im about to install my evo3 16g but im not sure if i wanna use the regular evo3 manifold that looks just like the stock one or use the tubular manifold which seems like it flows a lot better? is there any difference really? let me know guys thanx
The tubular manifold will give you better flow but, some crappy tubular manifolds have weak welds that will crack, the stock evo manifold is strong and very reliable.
Use the evo manifold there is no point on using a tublar manifold unless your really going for big power it will save you the headache later if the tubular cracks and leaves you stranded somewhere. Plus you can use your heat shield to reduce the under hood temp wich is vital to turbo cars so you don't pull timing.
stick with the evo manifold. theres really no need to go tubular if youre just going to run a E316g. most likely youll by a cheap tublar manifold too and itll end up cracking very soon.
