Turbo Kit
99SpyderGS
Feb 19, 2015
ridgely, Maryland
http://www.fastwayracer.com/Forced-...4-2.4L-SOHC-T3/T4-Turbo-Kit/product_info.html
I found this kit for the 4g64 Sohc 1995-2005. If I am wrong please correct me but the 2G 4g64 and 3g 4g64 are not placed in the same direction so how could the same turbo kit fit both motors also, will this turbo kit work if I bought it, I'm not a super genius with cars I know a few things also, I do not wanna use a 4g63 DOHC Head, I wanna keep it SOHC. Thanks any Imput is helpful!
Thanks I wasn't sure. I wanted to turbo my car but thought a kit would be awesome. I thought maybe it was ebay brand but wasn't sure.
Also you should know along with the all the parts for the turbo ( exh mani, I/c+piping, d/p etc) , you'll need larger injectors, fuel pump, possibly regulator. Most importantly a way to adjust fuel and spark timing, plus the engine will be ingesting more air so it changes the shape of the engines volumetric efficiency curve. This site has a lot of good info plus you can use a bunch of stock parts like a 1g bov, 5speed turbo injectors ( 450cc). I'm not sure how much power those stock pistons and rods can handle but tuning and avoiding detonation or knock is the most important thing.
Your better off making your own kit just find peope parting out theree dsms and get what ya can includeing bcs, wasttegate, sidemount ic, inJECTORS, ecu , rebuilt or rebuild a turbo 14b is fine for a conversion,bov, air canister with pipeing and maf 7 wire for the crappy boost gauge useless for nt cluster, oil lines return and feed, water pipe with coolent lines for turbo, throttle body butterfly plate thingy(not sure what the technical name for it is) to connect intercooler pipeing and bov to your throttle body,bov pipe thing that holds the bov, j pipe for turbo, exhaust manifold , banjoe bolts, knock sensor, injector resister paack, I got all this for under 200$ used for 1g from 2 differnt people it came witha never used rebuilt turbo now you stil, would need the following to make it run right and to handle the boost is... forged everything pistons, crank, rods ect.. so rebuild... and oil pan, dsm link v3 , wideband, oil gauge, turbo timer to cool the turbo abit, and off the top of my head thats it dont be afraid to add more but its alot chePer to build your own kit with oem parts hope I helped!
Thanks for the Imput guys I know about the intereals I just thought for the price it was too good to be true!
im not the best at turbos either, but i dont see why you cant get a kit like this and change parts later as you go so its not all a huge price right up front
Don't waste your money and time with this kit :nono: save and buy the legit stuff and you will be thankful later...trust me.
