Turbo kit install helllllppp!!!!!!!
IGNIGHT
Feb 12, 2010
EDWARDS, California
I bought this turbo kit off e-bay (I know you take a chance either way)Talon Eclipse Neon Stratus Avenger 420A 2.0L TURBO KIT Parts - DragTimes.com It was the most complete kit i could find at the time. I started the install with some friends and we keep hitting rough patches. Is there anything i'm going to need to pick up other then the obvious bolts and gaskets. Some advice as to where some of these things go would be much appreciated also like the Fuel Pressure Regulator. Thanks in advance.
This item has been shown times.
Rx Racing “Street Demon” Series 485HP Package Packing List of Included Kit Items:
Brand new “Street Demon” Series turbo package for your vehicle. The most complete turbo package available for the price. This package has all new quality parts that are capable of producing well beyond 485 horsepower at 25+ PSI with supporting modifications and a built motor. This is the most complete package available compared to others at an affordable price. On a stock motor the kit will create give the motor a 50-100 horsepower gain on a low boost setting of 8 PSI. Also, the included electronic turbo timer provides a hassle-free operation of precisely calculating the cool down period to ensure a proper cool down for your turbocharged motor. Works with either automatic or manual gearboxes. This kit may allow you to keep your air conditioning and power steering for a great street setup.
(1) Hybrid Turbo Charger:
.57 compressor wheel trim mapped for low & high boost setups
Oil fitting gaskets & mounting studs included
Capable of producing over 450 horsepower
Wet float bearings & properly balanced
3" inlet diameter with a 2" outlet
.50 A/R compressor housing
.63 A/R turbine housing
1/8 NPT oil inlet
T3/T4 hybrid
(1) Turbo Exhaust Manifold:
Cast construction for a long lasting street setup
High quality casting with large primaries
Strong design supports the weight of the turbo
Extra thick flange support the turbo well
High quality T3 turbocharger flange
Fully ported and polished design
(1) Front Mount Intercooler:
Large design cools down the turbocharged air efficiently
Strong TIG welds will support high PSI levels
Lightweight aluminum racing intercooler
Extra thick core provides ample cooling
2.5" cold outlet & 2.5" hot inlet
Less then 2% pressure drop
(1) Universal Intercooler Piping Kit:
Lightweight yet strong aluminum piping
May necessitate light modification to fit
(16) stainless steel worm gear clamps
(2) 2.5” 90 degree silicone couplers
(6) 2.5” straight silicone couplers
(2) 90 degree 2.5” bends
(2) 60 degree 2.5” bends
(2) 45 degree 2.5” bends
(2) straight 2.5” pipes
(1) Turbo Oil Line Install Package:
T fittings will fit almost any motor & still use factory oil pressure sending unit
Necessary fittings and clamps for a complete installation
18 inch 5/8” high temperature 550psi oil return line
Premium gaskets & hardware for the turbocharger
77 inch straight high strength oil feed line
Strong "T" fitting to hook up to block
Superior quality lasts a lifetime
Retails for $229 in magazines
High quality oil feed fittings
High quality turbo oil drain
Brand new turbo install kit
36 inch angle oil fee line
(1) Aluminum Battery Box Relocation Kit:
Full aluminum construction
Relocation cables, straps, hardware
Frees up lots of engine bay room
Better weight distribution for vehicle handling
(1) Boost Controller:
Can be setup to adjust boost PSI on the fly
Can be adjusted for any PSI level desired
Control your boost with a precise click
Includes complete install kit
Anodized aluminum finish
CNC machined design
(1) Blow Off Valve:
Protects turbo by venting when shifting and/or reducing throttle
Performance design produces a powerful & aggressive sound
Quality design will not leak under high boost conditions
Flanges installed at user discretion
(2) Slim Cooling Fan:
Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator
Slim design provides excellent engine bay clearance
Includes the mounting tabs for a easy zip tie install
Reversible design can either pull or push air
Versatility of a push/pull reversible fan
Superior flow of a curved-blade design
Creates additional aftermarket cooling
1.25" thick outside perimeter
2.50" thick inside perimeter
(1) Electronic Turbo Timer:
Ensures a proper cool down for your turbocharged car every time
Includes pigtail wiring and extra wiring for ease of installation
Important to preventing premature turbo wear and failure
Mounted inside the vehicle for on the fly adjustments
Precisely calculates the cool down period for the motor
Auto mode feature creates a hassle-free operation
Increases turbocharger's operating lifespan
Bright Easy to read LED Digital Display
Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo
Coking is the baking of oil, turning it into a grimy substance
(1) Fuel Pressure Regulator:
Great to setup fuel pressure for boosted engines
Precision pressure gauge
Fully adjustable
(1) Catch Can:
Stops excess oil from blowing to the intake manifold
Ensures better mileage & better performance
Removes oil vapors from breather line
Show like high quality polish
(1) Billet Aluminum High Flow Fuel Filter:
CNC machined T6-6061 billet aluminum construction
High flow capacity for demanding fuel systems
Strong brackets for easy mounting
High pressure fuel fittings
Anodized show like finish
Filter can be cleaned
6an sized fittings
Removable filter
(1) 35mm Wastegate:
Protect the turbo system from over boosting by venting surges
Includes complete install kit featuring gaskets and flanges
Strong construction provides years of reliable service
2 bolt flange style
(1) 10 Meters Heat Wrap:
Heat powers the turbochargers turbine inlet. Keep the heat inside the exhaust pipes
Heat kills the turbochargers compressor inlet. Keep the heat out of the cold piping.
Control additional engine bay heat and prevent overheating.
Keep intercooled air cooled.
Made of very high temp fiberglass.
(1) Stainless Downpipe:
2.5" Inlet
Waterjet cut 5 bolt flange.
Mandrel bent stainless steel
Beautiful TIG welds
(1) Radiator Hose Sleeving Kit:
Stainless braiding makes rubber radiator hoses up to 5x stronger
Makes engine bay look of show car quality
Strong construction provides years of reliability
Anodized ends for the authentic race like finish
(1) High Flow Intake Filter:
Protect the turbo system from debris
Instant HP adder
Extreme high flow
3" inlet perfectly matching the turbocharger inlet
(1) High Flow Breather Cap:
Extreme high flow
Keeps crankcase ventilation clean for emissions
Works in conjunction with the catch can to keep inside of turbo piping oil free
(1) Wastegate Positioning Adapter:
Allows adjustability for wastegate placement.
Laser cut flanges.
Mandrel bent stainless steel.
Beautiful TIG welds
2 bolt flange style
(1) Wastegate Dump Tube:
Allows wastegate exhaust gases to cleanly exit the engine bay.
Laser cut flanges.
Beautiful TIG welds
2 bolt flange style
(1) Coolant Sensor Bung
Monitor the water temperature via this sensor relocation
Easy solution to run aftermarket coolant sensor
Provides more precise readings then the stock location
Features 2 installation clamps for an easy add on
38mm ends fits most OEM coolant hoses
Strong Aluminum construction
IMO take it to a professional shop, I dont mean to come off as an donkeys rear but if you dont know where a fuel pressure regulator goes how in the world are you gonna tune the car for boost? If you dont want to do that then do some research on the site and all the answers will come in time.
I agree, you don't want to mess with things like this if you don't know where the basic engine/fuel components are located.
I'm not seeing anything for fuel management...You'll need more than the provided FPR to compensate for boost. At the least you'll need a 12:1 FMU, which can be paired with the regulator.
WOWOMG thats one hell of a kit! But most of that stuff you really won't need mostly cosmetic. (really a Battery relocation kit WTF) but like Tec sad you will need a 12:1 FMU, and it look like you also need a FCD(fuel cut defender) since you have a 97. the FPR you can cut it in to the fuel line that goes to the fuel rail and clamp it. But hay all that for less than $900 it has some potential but only time will tell:pray:
