turbo gauge
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
hey i just bought a gauge that shows vac press. also when i idle its at 0 and when i rev it it goes to -10 is that right... i thought it was suppost to be -20 at idle? does this mean vacum leak thank you
************ allllsoooo when i idle it stalls do you think this could be because of a " vacum leak " also thanx for your help guys
get a rubber connector to fit over the turbo inlet, with a pvc cap to fit the other end of the connector, drill a hole in the cap and put a valve stem in it, put clamps on both ends of the rubber connector and pressurize it, listen for leaks and put soapy water anywhere it could be leaking and watch for bubbles.
ok man thank you
It might look something like this when you are done. I added a 90° to make getting the connector from my air compressor on easier. But a valve stem and an tire compressor works fine too.
