Turbo Gasket Question
tom1995tsi
613
Nov 25, 2003
Hazleton, Pennsylvania
Ok I have a few questions, im removing my exhaust manifold, turbo, and o2 sensor housing. What gaskets will i need to buy to put them back on. And also what does an o2 sensor wrench look like? Thanks for the help.
you will need...
engine to manifold gasket
manifold to turbo gasket
turbo to O2 housing gasket
And, a O2 sensor socket doesnt work that good if your sensor is tight, because it just expands and wont turn the sensor. I would recommend getting the proper sized crows foot
Coldandafraid said:
you will need...
You can probably re-use the exhaust system gaskets, if they're i good shape. I re-used the exh. mani. to head gasket, and had no problems with it. The mani. to turbo, and O2 housing gaskets could have been re-used also, but I got them with the install kit so I replaced them. You will need oil return line gasket(s), and new crush washers for the water line banjo bolts if you remove them. You can rent a set of O2 sensor wrenches for cheap from an auto parts store, and a torque wrench too, for a few bucks.
What type of gaskets are they? Can I buy them at an auto parts store? Cause they didnt have the turbo mounting gaskets anywhere. Or are they a generic type gasket?
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
