Turbo,Engine Coolant Lines Question
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
im assuming that the 2 coolant lines after feed and return lines..
- The feed is the one closest to the block correct?
- The return line is the one closest to the radiator?
Now; where do i run those two lines too.. if u look in the picture there is a place to run a coolant line coming out from the block, and one coming out of thermostat housing..
Do i connect one line to the return line, and one to the feed line?
This picture is from another car.. is this how i should run my two lines?
Do you guys have an actual picture of were the front line goes??? I just bought a 97 gst and has no turbo coolant lines please help (noob) Thanks
