Turbo coolant lines question
tsitalon03
259
Jul 15, 2007
SouthRiver, New Jersey
Right now my car has a 16g with just oil feed/return lines. I'm gonna be installing a fp green this weekend and I wanna use coolant lines. The block is a 7bolt and the head is a 6bolt. I cant even find my coolant lines anywhere. Do I need 6 bolt or 7 bolt coolant lines. I never installed these lines before and I need to know where to tap them into. Here are two pics on how my lines look now.
You don't need them, it'll be fine with just the oil.
Edit: You probably have a mean exhaust leak seeing that your missing the bottom left exhaust manifold stud. And be carful you don't strip the threads in the head using bolts on the manifold. Should probably fix that before you throw on the green.
1G Studs from www.ssstuds.com
Yea I have a new set of ex mani studs, and I have brand new turbo to mani bolts. But looking at the pics, can you tell me where to tap in the water lines? I spent over 600 bucks to get this fp green rebuilt and I dont wanna take any chances.
