Turbo Clutch in NT?
1gentalonfan
236
Aug 17, 2005
Orlando, Florida
i have a 93 NT which im pretty sure is a 7-bolt :( and i need a new clutch and im looking at an XTD stage 4 racing clutch but its for the turbo will it work with my NT?
No it will not work..... the non turbo's have a single step flywheel and the turbo's have a dual step flywheel. Also the diameter of the clutches are different. Also, why are you wanting to put a turbo clutch in a non turbo?? The only thing I would worry about is if you have a turbo on your n/t motor other wise I wouldn't worry about it. Just don't but a stock clutch and you should be OK. :talon:
