Nt front case in turbo car
1gcrazy
1,552
9
Apr 6, 2005
Fountain, Colorado
So, a local guy dooped me into buying a nt front case(surprise)... Well he obviously isn't answering after I figured out the problem. Can I use this non turbo front case with my originally turbo car?
There are only two different front cases. 6 bolt and 7 bolt. As long as it's for the correct engine, you are good.
Well my 6 bolt oil filter housing won't fit the gasket. The gasket and front case are too narrow and the holes don't match up. Bottom of the front case is flat like a 6 bolt...
Let's see some pictures. If it is a DSM front case, there is only 6-bolt or 7-bolt. Any DSM 6-bolt front case will fit any DSM 6-bolt block. Same is true for the 7-bolt.
