Turbo Build anything else needed?
jjgrizz73
816
Feb 17, 2007
Carbondale, Pennsylvania
Hey everyone, I just bought all these parts for a turbo build I am doing in the next few weeks. Please give me any suggestions or opinions. Thanks alot!
-4g63t JDM motor
-MHI Evo III big 16g turbo
-Greddy 24r FMIC
-Greddy upper and lower intercooler piping
-Greddy Type RS BOV
-Apexi SAFC II
-Greddy Turbo Timer
-Slowboy Racing 3500 clutch
-Slowboy Racing ported 02 housing
-Walbro 255lph fuel pump
-Tubular turbo exhaust manifold
-TurboXS boost controller
-Cometic Head gasket
-ARP Head studs
-SS oil feed line
-Chrome smoked TB elbow
-1g 60mm Throttle Body
-Magnecor KV85 Competition spark plug wires
-Injen Air Intake
-PTE 580CC injectors
-K&N Air Filter
-Megan Racing FPR
-Innovate Wideband O2 sensor and gauge
-Autometer Phantom II boost guage
-Slowboy Racing SS J-Pipe
Still need-
Downpipe
High flow cat
Ummm, do you own another car (gst/gsx)? Because swapping in a 4g63 into a NT car is A LOT of work and you will need pretty much the front clip of a gst/gsx. If you already knew that I wish you the best of luck.
Otherwise with a quick scan it looks like you have all the turbo stuff.
The spyder comes with the 4g64 motor which is externally the same block, its not a 420a so a new clip and alot of fab work is not needed. This should be a fairly easy swap to do even though all swaps are a pain in the rear.
No but the JDM motor came with ECU, wiring harness, coil pack, etc.
