Turbo Boost seems weak and boosting low?
Matrixhunter
205
3
Sep 17, 2005
Toronto,
Hey guys just wondering what could cause low boost its seems like i have to really step on it to get any turbo performance but the car is in mint shape recently i put new tranny in so im just wondering could some vacum line of been unhooked which is causing it to boost low. I also Installed an aftermarket boost guage and it seems the highest im hitting on the 14b is like 9psi which is weak. It felt much stronger in the summer easily 11psi or so. Should i just install a boost controller and up the boost to solve the problem? thanks.
If you're wondering its a 1992 TSI
Sounds very much like you obtained a boost leak when you installed the trans. Very easy to do, especially since some of those hoses are probably dry and cracked. I'd start by going over all the vacuum lines and check any other plumbing you may have touched during the trans install.
Check to make sure you have the vacuum lines hooked up correctly, also another you may want to check would be the cat, Will cause slow and weak spool.
