tgounev
- 0
- Aug 5, 2007
Kansas City,
Missouri
The symptoms: The car would spool slow and can’t reach the max boost. Used to max at 24-25 psi – now it goes to 19-20 psi. You can hear a whoosh sound during boost – like something is deflating. The A/F gauges show lean condition during idle, which forces the LTFT to keep adding fuel, but the A/F ratio is fine during cruise and WOT.
What I did: First, I did a boost leak test and found leaks in the throttle body. I sent the TB to be refurbished (shaft seals, etc.) and when it came back, the intake leaks were gone. The BLT held good until 22 psi where the BOV starts to leak (I think that’s normal for 1G BOV, please correct me). Second, realizing that I must have an exhaust leak, I tested it with a shop-vac in the exhaust pipe and soap water. I had leaks on the exhaust manifold gasket and the turbo and O2 housing gaskets. I replaced all 3 gaskets. Had to put a helicoil in one of the manifold stud holes as it was stripped, which caused the leak on the manifold gasket, then used a Fel-Pro gasket for the manifold. Got the other 2 gaskets from ebay. They looked thinly made out of one layer steel. Put everything back and torqued the turbo and O2 bolts to 42 ftlb. Went for a test drive – same problem (maybe even slightly worse). I tested the exhaust side for leaks again. No leaks on the manifold gasket, but the turbo and O2 housing gaskets were leaking just as bad as before.
I am out of ideas. It has to be the exhaust leak. Would such a leak cause a 5 psi drop in boost and very lean idle? If it’s the gaskets, are there any more “forgiving”, thicker and softer gaskets I can use on the turbo-to-manifold and turbo-to-O2 surfaces? Thanks.
.... unless it's malfunctioning somehow. I can lower the boost, I just can't get it any higher. OK, so 15 psi is ok for the spring tension on the waste gate, and I can relax about it.
