turbo and n/t exhausts
truECLIPSE
367
Apr 4, 2004
209, California
Ok my question is in regaurds to exhaust systems. For example if you have a n/t car and you put a n/t exhaust system it will obviously work well. What if a turbo was added to the car would I need to exchange the exhaust system with a turbo one? If so is it possible to have a turbo exhaust system on a n/t car? or is it better to make the turbo mod first and then mod the exhaust system?
you can use stock GS-T ( not GSX) cat-back exaust in your car. It's bigger than your stock n/t exhaust and it'll work for 5-6 psi you'll run on stock motor. If you do engine mods, then you can get bigger exhaust if necessary.
