sweet97
- 2,386
- 18
- Mar 6, 2004
auburn,
New York
I just installed the Scanmaster from Full throttle and have found that my sidemount must be functioning poorly, not that it is probably very good anyways! I am running 14 PSI and even with an A/F of 10:1 I have knock under WOT. The sidemount must be the culprit. I know how to clean it but I have not run across anyone following up with postive results. Is this sidemount so bad that a few blasts at WOT cause it to heatsoak?
Has anyone removed th plastic cver in the wheelwell and replaced it with screening with say 1/4" holes? That should help the air flow thru quicker. Besides a frontmount what else can be done. Actually what I would like to know if anyone has gotten positive results as shown on a logger. thanks, Mark
