TunerPro tune help
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Just got a socketed eprom ecu and an ostrich 2.0 using TunerPro RT to tune for a few days until I get everything to run Speed Density. I just need a very basic tune from a nice enought TunerPro user to run the car for a few days. I have the E931.adx file downloaded as well as a .bin file downloaded. I just need someone to please do a generic tune because I have no other car and dont have a stock ecu anymore.
Only mods are a big 16g, walbro 255 and some RC 550s.
Please someone help me out with a Tune to get me running, I can turn the boost to whatever level is recommended.
Or if anyone has just a stock .bin file I can download, I know that will work okay.
If you intend to pursue stock ECU tuning via Tunerpro, you really should sign up, if you haven't already done so, @ dsm-ecu : DSM-ECU
As a member you have access to the file repository, which contains the E931 bin, as well as many others.
You can also obtain the stock bin from TunerPro and TunerPro RT - Professional Automobile Tuning Software
Also, you need to follow the link provided, and you will find all the necessary info to edit the bin to suit your current needs. http://www.dsmtuners.com/forums/152734331-post68.html
You'll also need the bin definition file, which can be found on TunerPro's website in the downloads section. Then load everything in TunerPro, and you can use the GUI to start getting things like injector comp, timing and fuel maps dialed in.
