TT Question
skreetracer87
60
Feb 16, 2005
Wingate, North Carolina
Ok I hooked my greddy tt and it wont count down completely. It starts at 1 min and get to like 55 or 56 seconds. Also the speedo thing keeps flashing odd numbers. Maybe wrong wire on the ecu i guess. I had to splice the harness. The guy i bought it from had cut the connector off the wires that go from the timer to the harness so i hooked the red to the two reds, the green to the greens and the blue to the blue. there are wires coming off the harness side that you can hook stuff to. Would it be because i have keyless entry and havent hooked that up yet?
If you have keyless entry do you have to hook the turbo timer up though the keyless wiring and all for it to work properly? I have a greddy and it keeps shutting down early like its loseing power and does have a constant source of power when i turn the car off so im tryin to figure out what my problem is.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
