Apexi TT Question
Booster-Shot
1,184
4
Jul 21, 2005
Napa, California
Well, Im in the process of removing the apexi tt from my talon. Its been so long since I put it in there I forgot how it all worked. I have 2 quick questions.
Theres 3 lines that I spliced. 2 for the ecu and 1 for the parking brake. If I cut those will anything stop working?
Also, I have the harness for the TT. I found where it plugs into my car, but once I unplug the turbo timer what plugs back into the car?
Thanks a lot-
If you cut the wires dont do it all at once. (they may be hot) Cut them 1 at a time.
As for the harness you got -- it goes in between the car factory ignition harness and the ignition switch.
you unplug that harness and then re-plug the connector back into the Ignition switch.
