Apexi TT wiring question
WSU99GSX
525
Mar 16, 2004
Peoria, Arizona
Okay I picked up an Apexi turbo timer and got it all wired up, o2 sensor wire and the ground are hooked up the the ECU. My problem is this, the harness that I got I don't think is right, it is an Apexi wire harness and the part number matches, however, when I have the harness hooked up my ABS light comes on, and most importantly me TT doesnt work, comes on for a sec. and then shuts off, but that light is on even when just the harness is in. Also there is an open spot on the harness and on the car side, but they don't match, could this be the wrong harness? If so is it possible to manualy wire this, like just splice it? Thanks.
Any help would be great guys, really what I would like to know is how to splice it in without the harness, since I really don't want to wait for another harness to get to me. I am pretty sure that one I have now is wrong.
Problem is most like your harness, since they didnt make a harness for 2g's, Which im assuming you have by your profile. Apexi only made a harness for 1g's. I have a apexi TT with a greddy harness and no problems for me. If you choose to splice the wires, just look in one of the threads it will give you the wiring layout and such. Good luck.
I found the wire layout that I needed, and ended up using parts of the harness that I got, thanks for the info.
