Tsudo N1 Fitment question
Infiltrate2000
172
Dec 27, 2003
QUEENS, New York
I have a megan 3 inch downpipe and had a shop install my tsudo N1 catback. I notice a noise and looked under the car. First, the big resenator after the downpipe, is hitting the heatshield, i guess i can just bend the heatshield upwards.
Secondly,the rear axleback, that goes over the rear frame, is touching. All the hangers are installed though.
Anyone had this problem before? I just dont want to take it back to the shop and its a problem with the exhaust design.
I had the same resonator clearance problem after installing a RRE downpipe on my Tsudo Fireball catback. I fixed it by bending the hanger arms on the downpipe so the exhaust hung a little lower. Half inch was all that was needed. Then there's the flange that connects the axleback to the resonator pipe and there's room to play with that flange's alignment. You'll probably be able to loosen that flange and find the best position so the pipe goes over the rear axle without hitting anything. A little bending of the rear hangers may be needed too though I didn't have to do that.
