truck problems?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Alright im not sure if im allowed to ask on here. But i have a IH scout2 and the spark from the coil is really weak. any ideas? also could a starter cause weak spark? cause sometimes i think the starters going out.
Usualy this kind of question goes in the hangout area, but what the heck. 1st, weak spark from your coil, most likely bad ground, coroded terminal connections, or just a bad coil. 2nd no, a starter will not cause a weak spark totaly unrelated. There ya go. p.s. to check to see if you'r coil is still good or not, pull up the specs for resistance on it, grab a multimeter and test. you can find detailed write ups off google, theyre everywhere, so i won't go into detail here. Good luck!
