alex99gst
- 1,335
- 24
- Feb 10, 2003
Nashville,
Tennessee
I just recently installed my new froun mount intercooler and MAFT setup and after driving around for a while I noticed that while the turbo is spooling up, I can hear the BOV sound like its opening a little bit. Its as if it is partially open and then when I let off the throttle it then acts normal. I was wondering if any of you guys running the MAFT setup had this happen and its normal or if I have a leaking BOV (the little flapper thing inside is ed somewhat). It feels like the car spools slower than it used to.
Another unrelated problem is with my datalogger. It works for things like knock, timing, rpm, etc... , but when it comes to O2 volts and fuel trims, they dont seem to change at all. Whenever I was driving around tonight the O2 volts never changed from 0.04-0.06v and the fuel trims didn't change at all until I was adjusting the idle knob and it said that the high trims went up to 199%. Does anyone know what is going on?
It's not about what I prefer, there are serious conseqences when tapping off the BOV line, one of them happens to be BOV openning prematurely/slightly under boost.
