Trouble shifting
nfernotalon
1,726
4
Aug 30, 2007
Greeley, Colorado
Hey guys, I just installed a new clutch on my car Tuesday because it was slipping in high gears anyway, it shifted fine before the new clutch and now im havin trouble getting it into gear especially reverse.
It doesnt grind or anything it just doesnt want to go in, I didnt open up the hydraulic system at all I just unbolted the slave cylinder from the tranny to drop it.
Also my master cylinder is adjusted all the way out since before and shifted fine and now it wont, any help is appreciated.:(
Im not sure what you mean?
How does the clutch pedal feel and where is the clutch engaging in correlation to the floor?
My pedal disengages in the same spot as before about halfway, thats working good just the shifting is hard to do now. My reverse worked fine now its a bi***.
Then I would bleed it and bleed it again. Make sure neither of your cylinders are leaking and readjust the rod.
