transmission
loudnproud
Jan 2, 2012
brandon, South Dakota
Ok noob question will a 1st gen 7bolt trans for awd fit a first gen 6 bolt awd engine
Ok because I'm about to buy a 1st gen talon and it has the 6 bolt swap (its a 93 body) so I wasn't to sure but I have the transfer case.drive shaft and rear in my 7 bolt were I'm getting the trans from so the splines on the inside trans will fit for sure because I don't know to much about transmissions I know how to replace them and a clutch but the difference between the splines to me looks the same
Will do.hopefully I get it in a few days I pray at least 2 gear syncos are going out and it spits alotta oil so if my trans will fit I would be ecstatic then its off to a full gasket kit head everything I wanna rebuild the whole thing I mean its bad what I can see I can only imagine some of the stuff I cant see
