Transmission output shaft seal to trnasfercase
DJDIGITALDEATH
Feb 12, 2003
I seem to have a heavy leak coming from the output shaft of the trans that is for the trasfercase, does anybody know what type of seal that is and where exactly its located? I pulled off my transfercase and can see the leak but it apears as if their is a bearing that the output shaft goes through and its flush mount with the inner bell housing case and no room for a rubber seal to pop in (like a drive axle seal) So is that seal internal? do i need to pull the shaft out to replace it? or has the bearing worked its way out flush poping the seal into the bell housing?
