Transmission Issue: Flakes in fluid
Semprini
299
Nov 14, 2006
Allentown, Pennsylvania
So I just swapped out the trans. I got this one from a friend, so I know the condition it was in, and it ran fine with about 70K on it. Its been 3 weeks now and it started making whining noises again, so I drained the fluid. It comes out greyish in color and you can see tiny metal flakes in it. WTF happened? It wasnt grinding or popping out of gear, so I dont know how bad it got. Any suggestions?
Whining usually means you fried the seals in the pump. aka the transmission is dead. it sounds sorta like a supercharger right?
When you put this trans in, did you flush the transmission lines and such from the debris the old trans left behind? If not then you most likely loaded a ton of crud into the unfiltered side of the trans, and clogged up the pump and torched the seals.
If not, then I would say you are a bit low on trans fluid.
