Transmission help. shift forks.
DSMBanditFZ6
2,085
Nov 17, 2011
Somewhere, Arkansas
Ok, before I ask. I did use the search button and looked for a while on this topic, thanks.
My transmission while driving will only go into second gear under 2000rpms. Even then it kinda fights it no other gear does it that bad, I am thinking the 1-2 shift fork is bad and I will be replacing it. and after searching for how to threads I cannot find one. The transmission is pulled. is there a way to just check it? What really needs to come off?
Sorry if this is a repost I did attempt to search our forums to resolve this issue.
I have the haynes manual but a little bit more confidence would help. Thank y'all for y'alls time.
Haynes wont help gonna have to pull it apart and check out the internalls, to make sure completely unless im incorrect, dont know of any way to inspect.
GL5?
And wow that colt is about as fast as my motorcycle.
awsome
GL5?
awsome
