transmission fluid, to switch or not to switch?
bronson
Dec 18, 2005
zion, Illinois
my car is runnung with synthetic trans fluid now, is it safe to drain and switch to non synthetic fluid.
well the reason being is that i was using formula one trans fluid and i was reading on a forum a while ago that pennzoil synchromesh was the way to go. And since the bottle doesnt say anyting about it being synthetic and the formula one does, i didnt want to make the switch without knowing that it's safe.
Ahh, I use synchromesh, and, well, I just put it in, but my car doesnt move right now due to a clutch problem, so I cant tell you if theres a big improvement in shift quality, but I also heard that it is the way to go, and if you dont have a lot of power, or you dont race your car all the time and put a lot of stress on your tranny, then synchromesh would be fine.
ive always known people to use syncromesh as well. i personally have a pretty used trans....i put synchomesh in and now it grinds more...im going to switch back to heavy weight...but thats just because its screwed...
I used GM Synchromesh at one point too. Not impressed one bit. It was no different then the cheap Napa stuff that was in it before. I just bought some Redline MTL and MT90. I will be putting that in once the car is out of storage. I've heard great things about using that mix, so we'll see how it goes!
^ Good experience with both Redline and Royal Purple......
I personally use Mobil 1 10w-30 synthetic, but then again I'm running a getrag.
well till now i have been using the mobil 1 75-90. i never had a problem with it besides the price. i just got the pennzoil synchromesh cause of a forum claming it to be the best. i have yet to switch. should I?
well i just got done switching tran fluid from the mobil 1 to the pennzoil synchromesh and i got to say way better way way better car runs and feels better.
